42MB Upload, Who's Jealous ?
markg140
Check this, confuzzled ?
36 REPLIES 36
lexusuk
Re: 42MB Upload, Who's Jealous ?
Hi markg140,
Looks like a testing error.  What happens when you test at http://www.mybroadbandspeed.co.uk/ ?
markg140
Standard 1.9Mb's
How come BT's speedtester is showing this though that should be the most accurate should it not ?
lexusuk
Quote from: markg140
This type of thing is usually caused by an out of date version of Java or some kind of browser issue.  If you did the test with another browser with the lastest version of Java no doubt you would find the results consistent with mybroadbandspeed.co.uk .
markg140
Updated version of Java;
43Mb Download
11Mb Upload
prichardson
According to the Speedtest results we can see stored remotely, this test was not conducted using the Plusnet connection. The IP recorded was a third party provider.
Are you connected via VPN at the time of the check?
markg140
I may be in for a bit of an embarrasment here but.
This test can be run remotley can it not ?
Seen as your enter your telephone number and they run it down that line ?
prichardson
Unfortunately not.
The test needs to be conducted on a machine, utilising the connection that has a problem. i.e your physical machine at home.
The telephone number entered is to allow the network to load details about your line and to allow it to record the result against your connection records. It validates you are connected to ensure a basic level of information it is testing against the correct line.
In your case, provided your home connection was online at the time of the test, it will have allowed the test to complete.
Gus
Some virus scanners have been known to give corrupting results, try disabling yours during the test.
FTTP 500 regrade from Tues 28th November
pierre_pierre
Re Java look at his screen shot on the first post Crazy Crazy
Java was out of date
markg140
Policy ID: FTTC FTTC
Profile Rate: 2000 37614
Test File Size: 78692680 141498120
File Transfer Average Throughput/Session: 12370.4482421875 50743.8125
That's what Plusnet's support is telling it gets for results too.
Note the 50Mb/s and 12Mb/s for upload.
Doubt this is a mere java problem.
knowdice
Are you getting these results on a computer that is connected to YOUR FTTC broadband?
or as is suggested above from and alternative location?
markg140
The post above was plusnet testing it at 50Mb/s and 12Mb/s up.
I find it unlikely Plusnet would use the wrong testing methods.
knowdice
What did P Richardson mean by this?
Quote from: P
markg140
That I conducted the test at work.
I was under the impression seen as you enter your telephone number it ran the test to that line without somebody physically having to be there, it seams that assumption was incorrect.
This doesn't deduce from the fact that when Plusnet are testing they obtain 50/12.
