3rd party router not connecting
- 3rd party router not connecting
04-09-2018 10:27 PM
I've picked up a Netgear DGN2200v3 ADSL router from one of my friends.
I've been trying to use it as a replacement for my Plusnet router but the Netgear doesn't seem to connect. Keeps on saying that there isn't an ADSL connection.
I know what my username and password for the connection should be.
Message 1 of 2
(422 Views)
1 REPLY 1
Re: 3rd party router not connecting
05-09-2018 11:48 AM
Hi @unabatedshagie,
If you are on a Fibre package then an ADSL Router won't work unfortunately, so if you are on a Fibre package then I would recommend trying to use a VDSL Router instead.
Message 2 of 2
(387 Views)
