198.18.1.x address problems
Anotherone
Champion
Fixes: 21
Re: 198.18.1.x address problems
Kevin, I have told you before, this is the 582n spooflist (the intercept cache table). It gets filled with entries when DNS lookups fail. You need to find out why your DNS lookups are failing. I think most people will get an occasional one which is why you'll find entries in it.
Telnet into the 582n -
then do      dns server debug spoof list    which will show the last ones that failed. IIRC the table is limited to 32 entries, and so will start over-writing the earliest when it fills up.
There's the commands - dns server debug spoof update & dns server debug spoof clear which I've used. An example of my current entries and use of the update command below -
[xx]=>dns server debug spoof list
Spoof IP          FQDN                         Real IP          Flags
198.18.1.1       www.google-analytics.com     0.0.0.0          Not resolved
198.18.1.2       delivery.ads-creativesyndicator.com 0.0.0.0          Not resolved
198.18.1.3       ads.captifymedia.com         0.0.0.0          Not resolved
198.18.1.4       www.linkedin.com             0.0.0.0          Not resolved
198.18.1.5       ib.adnxs.com                 0.0.0.0          Not resolved
198.18.1.6       rs.gwallet.com               0.0.0.0          Not resolved
198.18.1.7       fw.adsafeprotected.com       0.0.0.0          Not resolved
198.18.1.8       b3-uk.mookie1.com            0.0.0.0          Not resolved
198.18.1.9       ad.doubleclick.net           0.0.0.0          Not resolved
198.18.1.10      app.rain-alarm.com           0.0.0.0          Not resolved
198.18.1.11      qos.video.yimg.com           0.0.0.0          Not resolved
198.18.1.12      googleads.g.doubleclick.net  0.0.0.0          Not resolved
198.18.1.13      static.licdn.com             0.0.0.0          Not resolved
198.18.1.14      ajax.aspnetcdn.com           0.0.0.0          Not resolved
198.18.1.15      r.turn.com                   0.0.0.0          Not resolved
198.18.1.16      tpc.googlesyndication.com    0.0.0.0          Not resolved
198.18.1.17      recs.richrelevance.com       0.0.0.0          Not resolved
198.18.1.18      0.client-channel.google.com  0.0.0.0          Not resolved
198.18.1.19      mail.google.com              0.0.0.0          Not resolved
[xx}=>dns server debug spoof update
[xx}=>:dns server debug spoof list
198.18.1.1       www.google-analytics.com     216.58.208.32
198.18.1.2       delivery.ads-creativesyndicator.com 78.129.139.124
198.18.1.3       ads.captifymedia.com         37.252.162.56
198.18.1.5       ib.adnxs.com                 37.252.162.56
198.18.1.6       rs.gwallet.com               208.146.36.221
198.18.1.7       fw.adsafeprotected.com       69.172.216.56
198.18.1.8       b3-uk.mookie1.com            208.81.234.158
198.18.1.9       ad.doubleclick.net           216.58.208.38
198.18.1.10      app.rain-alarm.com           54.229.52.60
198.18.1.11      qos.video.yimg.com           98.137.201.111
198.18.1.12      googleads.g.doubleclick.net  216.58.208.34
198.18.1.13      static.licdn.com             87.248.214.64
198.18.1.14      ajax.aspnetcdn.com           68.232.34.200
198.18.1.15      r.turn.com                   46.228.164.11
xx=>:dns server debug spoof update
xx=>:dns server debug spoof list
198.18.1.4       www.linkedin.com             91.225.248.129
198.18.1.16      tpc.googlesyndication.com    74.125.230.108
198.18.1.17      recs.richrelevance.com       204.93.252.69
198.18.1.18      0.client-channel.google.com  173.194.67.189
198.18.1.19      mail.google.com              216.58.208.37
xx=>exit
Strange how they didn't all update the first time! There's also dns server debug spoof getaddress <addr>  where <addr> is the spoofed ipv4 address to look up. I've not used that command.
Fixes: 161
Quote from: Anotherone
Anotherone,
If you had told me that, I think I would have remembered.   Wink Cheesy
My observation though is that if this were a router issue, then I would expect the problem to be seen across a number of devices - it has only been seen on the Win8.1 platform and disappeared when that platform had its DNS server changed and remained "corrected" when the DNS resolver was switched back to the TG582n.
I have just looked at the list and do see some strange entries - many of which I have no intentional attempt to connect to.  Shocked
{Kevin}=>dns server debug spoof list
198.18.1.183     img.stb.s-msn.com            0.0.0.0          Not resolved
198.18.1.184     appexbingweather.trafficmanager.net 0.0.0.0          Not resolved
198.18.1.185     go.microsoft.com             0.0.0.0          Not resolved
198.18.1.186     img.s-msn.com                0.0.0.0          Not resolved
198.18.1.187     ws12.gti.mcafee.com          0.0.0.0          Not resolved
198.18.1.188     apis.google.com              0.0.0.0          Not resolved
198.18.1.189     fbcdn-sphotos-f-a.akamaihd.net 0.0.0.0          Not resolved
198.18.1.190     fbcdn-creative-a.akamaihd.net 0.0.0.0          Not resolved
198.18.1.191     dns.msftncsi.com             0.0.0.0          Not resolved
198.18.1.192     sqm.telemetry.microsoft.com  0.0.0.0          Not resolved
198.18.1.193     edge.quantserve.com          0.0.0.0          Not resolved
198.18.1.194     d.p-td.com                   0.0.0.0          Not resolved
198.18.1.195     rtd.tubemogul.com            0.0.0.0          Not resolved
198.18.1.196     pixel.tapad.com              0.0.0.0          Not resolved
198.18.1.197     p.univide.com                0.0.0.0          Not resolved
198.18.1.198     cm.adgrx.com                 0.0.0.0          Not resolved
198.18.1.199     plugin.mediavoice.com        0.0.0.0          Not resolved
198.18.1.168     www.samknows.com             0.0.0.0          Not resolved
198.18.1.169     sls.update.microsoft.com     0.0.0.0          Not resolved
198.18.1.170     fe2.ws.microsoft.com         0.0.0.0          Not resolved
198.18.1.171     www.fujitsu.com              0.0.0.0          Not resolved
198.18.1.172     ssl.gstatic.com              0.0.0.0          Not resolved
198.18.1.173     www.gstatic.com              0.0.0.0          Not resolved
198.18.1.174     urs.microsoft.com            0.0.0.0          Not resolved
198.18.1.175     www.google.com               0.0.0.0          Not resolved
198.18.1.176     updatekeepalive.mcafee.com   0.0.0.0          Not resolved
198.18.1.177     www.google.co.uk             0.0.0.0          Not resolved
198.18.1.178     client.wns.windows.com       0.0.0.0          Not resolved
198.18.1.179     sports.services.appex.bing.com 0.0.0.0          Not resolved
198.18.1.180     en-gb.appex-rf.msn.com       0.0.0.0          Not resolved
198.18.1.181     watson.telemetry.microsoft.com 0.0.0.0          Not resolved
198.18.1.182     su3.mcafee.com               0.0.0.0          Not resolved
The emboldened items I have (during looking at the issues on the Win8.1 platform) successfully connected to on the Win7 plat form - BOTH devices are using the same TG582n resolver - this is not making sense to me.
EDIT: As you suggest, the real point of interest here NOW is why these addresses are not getting resolved?  Is one looking at a TG582n issue or (another) PN DNS issue?
Kevin
Anotherone
Champion
Fixes: 21
You will notice in my list that I'd posted pages that I have not visited (or wish too!), they are because pages that you have visited, will have had links, ads, or images etc. to/from those sites. They only need to fail on one occasion to appear in the table.
Fixes: 161
Grrrr!!
It has come back again!
There are no unresolved names in the TG spoof list.
ipconfig /displaydns makes no sense.
C:\Users\Kevin>ipconfig /displaydns
Windows IP Configuration
   wpad
   Name does not exist.
   plus.net
   Record Name . . . . . : plus.net
   Record Type . . . . . : 1
   Time To Live  . . . . : 44049
   Data Length . . . . . : 4
   Section . . . . . . . : Answer
   A (Host) Record . . . : 212.159.9.2
   A (Host) Record . . . : 212.159.8.2
C:\Users\Kevin>ipconfig /flushdns
Successfully flushed the DNS Resolver Cache.
Could not display the DNS Resolver Cache.
   Record Name . . . . . : client.wns.windows.com
   Record Type . . . . . : 5
   Time To Live  . . . . : 36
   Data Length . . . . . : 8
   CNAME Record  . . . . : wns.notify.windows.com.akadns.net
   Record Name . . . . . : wns.notify.windows.com.akadns.net
   CNAME Record  . . . . : db3.wns.notify.windows.com.akadns.net
   Record Name . . . . . : db3.wns.notify.windows.com.akadns.net
   CNAME Record  . . . . : db3ab.wns.windows.com
   Record Name . . . . . : db3ab.wns.windows.com
   A (Host) Record . . . : 157.55.44.125
   db3wns4011707.wns.windows.com
   Record Name . . . . . : DB3WNS4011707.wns.windows.com
   Time To Live  . . . . : 1796
   A (Host) Record . . . : 157.55.236.121
   isatap.lan
   Time To Live  . . . . : 956
   wpad
Thoughts anyone please?  Does this look like malware at work?  This is my new(ish) play platform whose "trial" AV expired on 12th Dec and I've yet to update it - this weekend's job which at present I cannot do due to URL resolution issues!  Crazy
picbits
Have you tried uninstalling the AV totally ?
Fixes: 161
No, I'm trying to update it.  Will try the uninstall!  Cheesy
EDIT: McAfee uninstalled / Re-installed / Rebooted and all fine... for an hour or so - broken again!
Totally confused!  TG did report more unresolved spoofs - reason not known.
Google DNS resolves g.microsoft.com to different address to TG/PN DNS.
Wim8.1 platform cannot connect to g.microsoft.comn Win7 is OK.  Crazy Crazy Crazy Crazy
    go.microsoft.com
    Record Name . . . . . : go.microsoft.com
    Time To Live  . . . . : 414
    CNAME Record  . . . . : www.go.microsoft.akadns.net
    Record Name . . . . . : www.go.microsoft.akadns.net
    A (Host) Record . . . : 64.4.11.25
C:\Users\Kevin>ping go.microsoft.com
Pinging www.go.microsoft.akadns.net [64.4.11.25] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 64.4.11.25:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\Kevin>tracert go.microsoft.com
Tracing route to www.go.microsoft.akadns.net [64.4.11.25]
over a maximum of 30 hops:
  1    5 ms    4 ms    4 ms  dsldevice.lan [192.168.1.254]
  2    52 ms    58 ms    79 ms  lo0-central10.pcl-ag07.plus.net [195.166.128.188
  3    70 ms    74 ms    79 ms  link-b-central10.pcl-gw02.plus.net [212.159.2.18
6]
  4    78 ms    64 ms    78 ms  xe-9-0-0.pcl-cr02.plus.net [212.159.0.218]
  5    71 ms    82 ms    66 ms  ae2.pcl-cr01.plus.net [195.166.129.6]
  6    70 ms    77 ms    76 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
  7    74 ms    71 ms    71 ms  ae2.ptw-cr02.plus.net [195.166.129.5]
  8    *        *        *    Request timed out.
  9    *        *        *    Request timed out.
10    *        *        *    Request timed out.
11    *        *        *    Request timed out.
12    *        *        *    Request timed out.
13    *        *        *    Request timed out.
14    *        *        *    Request timed out.
15    *    ^C
C:\Users\Kevin>nslookup
Default Server:  dsldevice.lan
Address:  192.168.1.254
> go.microsoft.com
Non-authoritative answer:
Address:  64.4.11.25
Aliases:  go.microsoft.com
> server 8.8.8.8
Default Server:  google-public-dns-a.google.com
Address:  8.8.8.8
> go.microsoft.com
Address:  8.8.8.8
Address:  134.170.184.137
> exit
C:\Users\Kevin>tracert 134.170.184.137
Tracing route to 134.170.184.137 over a maximum of 30 hops
  1    8 ms    6 ms    4 ms  dsldevice.lan [192.168.1.254]
  2    44 ms    37 ms    52 ms  lo0-central10.pcl-ag07.plus.net [195.166.128.188
  3    47 ms    45 ms    46 ms  link-b-central10.pcl-gw02.plus.net [212.159.2.18
6]
  4    46 ms    46 ms    46 ms  xe-9-0-0.pcl-cr02.plus.net [212.159.0.218]
  5    46 ms    45 ms    47 ms  ae2.pcl-cr01.plus.net [195.166.129.6]
  6    47 ms    44 ms    46 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
  7    46 ms    46 ms    46 ms  igblmdistc7504.uk.msft.net [195.66.224.140]
  8  116 ms  119 ms    *    ae15-0.nyc-96cbe-1b.ntwk.msn.net [207.46.45.225]
  9  139 ms  133 ms  133 ms  ae5-0.yto01-96cbe-1b.ntwk.msn.net [207.46.39.118
10  133 ms  132 ms  134 ms  ae0-0.yto01-96cbe-1a.ntwk.msn.net [207.46.38.56]
15  169 ms  168 ms  174 ms  ae2-0.cys01-96cbe-1a.ntwk.msn.net [204.152.140.1
16]
16    *        *        *    Request timed out.
17  191 ms  190 ms  190 ms  191.234.82.236
18    *        *        *    Request timed out.
19    *        *        *    Request timed out.
20    *        *        *    Request timed out.
21    *        *        *    Request timed out.
22    *        *        *    Request timed out.
23    *        *        *    Request timed out.
24    *        *        *    Request timed out.
25    *        *        *    Request timed out.
26    *        *        *    Request timed out.
27    *        *        *    Request timed out.
28    *        *        *    Request timed out.
29    *        *        *    Request timed out.
30    *        *        *    Request timed out.
Trace complete.
npr
Fixes: 9
Quote from: Townman
Do you really want to run McAfee that badly ?  Cheesy
picbits
Try uninstalling McAfee and run it on trusted websites for a couple of hours.
npr
Fixes: 9
Or just enable windows firewall and install windows defender  Wink
Quote from: npr
It's worse than that,
  Do you really want to run Windows that badly ?  Cheesy
npr
Fixes: 9
Quote from: purleigh
Grin Grin Grin
Yes  Cool
Fixes: 161
Funny guys!  Grin
Well Wiin8 has finally finished doing its updates which are not exactly verbose about anything actually happening.  I'm now wondering if this problem is related to busy background coms.
I set the DNS to 8.8.8.8 for the duration (on the Win8 NIC) and successfully completely updated Win8.1.  Really am learning to hate this version of Win with a real passion!
Now that the updating is complete, I have switched the DNS settings back to auto and will monitor what happens.
The whole thing has been quite confusing; in the past when I've seen these spoofed IPs it has been down to PN DNS issues and on my WIn7 platform.  As above, today they have been seen only on the Win8 platform connected to the same router which has been working without issue for the Win7 PC.
DNS resolutions appear to be largely as expected, put pings refer to a spoofed IP.  Completely confused as to what has been happening and why.
Any wisdom from the PN team would be most welcome.
Thank you to everyone for their input today - you just about stopped me throwing this piece of kit through the window, thereby avoiding me being cold this Christmas!  Grin
Kevin
You could have ceremoniously set fire to it,  then you wouldn't be cold or have a broken window !  Cheesy
If anyone asks what on earth are you doing, just say you are testing the Windows firewall  Grin
Anotherone
Champion
Fixes: 21
Grin Grin Grin Sorry Kevin, I know your problem isn't funny, but that was.  Crazy
Fixes: 161
Anotherone,
The secret of a good life is to have fun and laugh when you can - do not take technical trials too seriously.  It has been trying weekend, this episode was preceded by configuration difficulties with an OKI printer, which apparently has a less than obvious configuration save / apply procedure.  To say nothing of extending a network on a router to which I have no admin access!
Thank God tomorrow is another day, even if is is a Monday.  Grin
Kevin
