wireless router suggestions?
Hi, i thought i would seek advice from all you clued up people out there.
i would like to purchase a wireless router for my MAC G3 iBook ( No airport card)
so any suggestions as to which router and more importantly,'compatable' USB wireless connecter would be useful.
Thanks in advance
Mick
i use an smc router and theres never been any problems so i would recommend one of them,
www.broadbandstuff.co.uk
that page has all of the information about it Smiley
[Moderator's note by Jonathan (chillypenguin): URL converted to a link as it was stretching the forum page.]
Looks a good bit od kit, do you use it with a iBook or similar?
I assume the router is not the problem it's getting a compatible adaptor for my laptop.
My understanding is that you need to be using MAC OS 10.2 or higher to get drivers for a USB wireless adapter. Provided that you are, then any USB wireless adapter will work.
