wireless keeps going out
hi, ive got a D-Link 2740B - erm recently i caught a virus and formatted, now when i boot up my router the wireless works then the light goes out and so does the wireless, how can i fix this : (
help much appreciated
The_10th
Are you saying that you can connect to the internet wirelessly via the router from your PC but then the router switches off its wireless capability?
yes, if i reboot the router the wireless comes back on but after abit the light turns off and the wireless network is no longer there but if i run a diagnosis test from the router page it says wireless is active
hmm another odd thing ive noticed my router keeps timing out after say 3/4hours :/
The_10th
There is normally a setting on a router to stay connected or disconnect if idle after so many minutes, e.g. 180mins which may be what is happening.
I found that there has been a firmware update see this which has a manual for the product also at bottom of the page.
yeah, i saw that early on as well - ive updated the firmware, somehow i think it has something to do with my ethernet card..ive tried a different set of drivers hopefully it fixes this issue, although this firmware allows me to change my mtu ...its still stuck at 1440 : (
grr doesnt seem to be working, is it possible the router may be damaged?
ive tried the following:
*rebooting
*restoring factory defaults
*updating, downgrading firmware
*changing wireless settings
*changing NIC drivers
*Plugging router into another power socket
The_10th
What I find weird is that you say this happened after your PC was infected with a virus? Have you another router you can get hold of or another PC/laptop to try even to eliminate that if the Virus is behind this?
no, but i did disconnect the router from my pc and just let it run on wireless alone, still no difference Cry
