wireless and services
Everytime i restart my PC i have to go to services and start the wireless zero config or sumit like that service. I have a wireless network at home and i have to do this to all my Pc except my laptop...
Its set to autoimatic but it just stops at every reboot.
Can i not avoid starting services everytime....
1 REPLY
You dont say what router and network card you are using. Normally you only need to start the service if you are trying to use the windows service instead of the one that came with the card.
If you use the software with the card you should need to start this service
If you want to start it on startup open notepad and create a file wire.cmd
type
net start wzcsvc
save the file to c:\
put the file wire.cmd in your startup group and it will then run on startup
