wifi access
wifi access
I can't check, it's a shotcut on my PDA but I can't view the actual URL and the link only work when connect via the hotspot. The http:// will have to be entered but this is normally put in automatically by your browser. When you do connect to a hotspot a BT Openzone login page is automatically loaded and I believe there is a link for Plusnet within this page. Be sure that you log out as you still be charge, not sure if there is an automatic idle logout, if there is it could be several 10's of minutes.
wifi access
Hello,
Its not clear to me if I, as an existing broadband customer with plus net, I sign up for per-minute scheme wifi/wireless broadband scheme if I will be charged an additional fee for the service apart from the declared 7p per minute. I raised a ticket through the my questions thingy but it has been there since Sunday 11:46 - way past the '7 hours to answer all questions' time limit suggested somewhere recently - so I doubt if it will get answered. I know asking the question twice increases their workload but it relieves my frustration and its their fault not mine. If 92% of users are satified with Plus Net what are the other Broaddband suppliers like? I choose Plus Net because when Internet Magazine was published it [Plus Net] always came out in the top 10 of customer satisfaction and speed fo service for broadband.
wifi access
To answer your specific question regarding WiFi PAYG you will only be charged when you use it. There are no other charges. You can also check your usage through Your Account. Beleive this is updated every 15 minutes. By the way you can only use BT Openezone sites Cloud and the others will not work.
wifi access
Thank you for your quick reply - much better that the ticket I raised - still there waitiing!
One further question - when it says type wifilogin.plus.net into your browser is that all, does it need a www. or a http:// in front?
Paul
wifi access
The idle logout is 15 minutes in Openzone ..
