wifi access points
wifi access points
Surely wifi access is not dependent on commercial agreements between PlusNet and wifi vendors such as BT OpenZone.
Is it possible for anyone with a wireless router (and broadband connection) to turn their immediate locality into a wifi hotspot so that roaming users can connect? (http://www.wififreenet.com/free.html).
In which case, as was touted in a previous topic, PlusNet users could open up a sizeable 'roaming' network. :?
wifi access points
But surely the idea of this product, is to aloow access to an established network of hotspots?
Beyond which, I believe such a project is against the contract of the PlusNet products. In which you are not allowed to resell service.
wifi access points
I'm not disputing the benefits of BT OpenZone or the benefits of any commercial arrangements between BT OpenZone, PlusNet and other ISPs.
A previous thread (Roaming) raised the question re PlusNet users providing such a network.
I'm also not proposing that the point provider charge for the service. So the question of reselling doesn't come into it.
The only benefit I might expect - apart from, perhaps, a large and free network on which to roam - is payback on referrals to the PlusNet network, if PlusNet are able to derive any benefit / charging model from such a service. (possibly as defined on the previous link).
wifi access points
providing free access to a WiFi network in such a way, produces a second clause to block the path.
No services are supposed to be provided on your connection, unless some form of ACL is in place.
