which router?
curati
which router?
I'm new to broadband but am thinking of getting myself a wireless router. Which routers do users of plus.net broadband recomend? Or maybe a better question would be which routers should I definately avoid.
I know that plus.net sell a "bt voyager 2100" for about 80 quid. I may opt for this if I have to, but I've seen cheaper options such as lynksis for about 40 quid, and even cheaper still on ebay.
Thanks for your help
which router?
I will always choose and recommend Netgear. Stable, reliable and well priced.
You wont go far wrong with these.
More info here
which router?
Netgear is a good solid brand. Other ones to look out for are Linksys, Belkin and D-Link.
I have a Belkin box and have been very pleased with it.
markjeffs
which router?
the netgear DG834GT are very good but they have also released a Mimo box now with better wireless ranges
try here www.lanserveuk.com
they will help you
