voyager 2110 and cs 1.6
i have a BT 2110 router.... been on portforward.com, which is great and helped with WC3, but allas nothing worked regarding steam.
I can connect to games no problem... it seems to be when the 2nd pc connects.
When 2 pc's connect to cs (clan war) all is fine for 20 mins or so then all of a sudden BAD ping spikes and cl_flush entirty packet crap pops up and both pc's close cs?
Has this happend to anyone else?
I have changed the ports that cs connect to on steam (+clientport 27005 etc) and followed the portforward site but still the same....... i need help
thanks in advance
1 REPLY
not sure... as far as I know on most domestic routers, you can only portforward to one internal address. That doesnt explain why it works for 20 minutes as you've said. Maybe your NAT tables are filling up - I don't know how many NAT tables the BT voyager supports. You could also try connecting both PC's to games with only a few players
