vista see my wireless router but dons't connect to the net
I have a linksys setup consisting of 2 wireless usb adapters wusb54g ver 4 and a linksys wirlesss home gateway wag354g.
I'm connected to the net at present on the 2nd computer using xp and all is fine.
I canot however get vista to connect. I am using the drivers on vistas site for the usb adapters but I'm getting nowhere.
Can someone help
ON checking the properties for vista connecdtion to my network it lists IPV4 and 6
can someone help I'm going mad and getting grayer
A
holdtight
Are you using the 64 bit version of vista as ive found with XP pro 64 bit i cant get any of my wireless kit to work regardless of the supposed 64 bit drivers the manufacturers have for download, properties say the device is there but no its not
Netgear have stated they have no intention of creating any 64 bit drivers for there wireless cards / adapters not sure about linksys though i havnt looked
I dual boot at the moment between xp pro 32 bit and pro 64 bit which has to be hard wired to my DG834PN for net use thats without the many other drivers still not available for most of my other hardware Evil
Makes me wonder why i bothered as theres no performance increase been 32 and 64 bit despite running 2 gig of DDR2 ram and an AMD 4200+ X2 @ 2.5ghz
"sigh" rant over Wink
I dont know if any of this applies to your system though
This is a new security feature of Vista as it makes it more secure if you dont connect to the internet(joke I think).
Give us a clue can you ping other pc's on your network can you do a ipconfig /all so we can see whats happening and compare it to xp's. The ip 4 and 6 should both have the same settings
I'm using 32 bit ed.
IPV4 is saying local
IPV6 is Limited
Can't ping message is transmit error code 1231
A
I think I must have been sleep walking. I woke up this morning and turned on the pc and it just worked. I spent 6 hrs at least last night getting nowhere.
All fixed.
Thanks for evenyones help.
A
