unlocking the home hub
greg16
finally got the homehub to unlock after connecting it to the pc and trying thru that (was using laptop b4)
haven't got all the features that the new firmwire of the home hub gives but that no biggie.
i don't seem to be able to get wireless connection though, my Access point doesn't pick up the hub and vis versa.
i have my phone connected but all calls go thru my landline, does anyone know how to fix this
greg16
HI,
has anyone else got the BT homehunb and managed to unlock it as per the below link.
http://www.the-scream.co.uk/forums/t22917-13.html?
i have tried about 15 times and can only get the update to go as far as 16% then it fails.
Did you use a hex editor and change the text ok?
I did it on one and it went ok
greg16
hi right,
yeah, i followed the step by step guide that the man put up on page 13, the only difference was that my version said 6.1.9.6 or sumthing instead of the 6.1.6.? that his one said.
but earlier posts ppl had the same version number as me and they changed. some of them do say to just keep going at it.
i even tried the other firmwire copy but samething.
what like is the homehub on plus net after u unlocked it.
