netgear834
timps
netgear834
Hi need to upgrade from a usb adsl modem to a wireless set up.
not overly tech but have made a decision on DG834 should i be looking at GT or PN range is not really an issue.
any advice will be helpful
Thx Tom
netgear834
IMO a very easy router to set up and use. Recommend
Craigiusmaximus
netgear834
Lots of people on this forum use them very popular choice think ill get one when my linksys goes.
netgear834
There are 2 variants of this router - a wired and wireless. I would recommend the DG834 (or DG834G if going wireless). Lots of people swear by the DG834/G and there's lots of help available here if you need to set it up.
Netgear no longer support the DG834GT, and is has proprietry wireless.
I cant really comment about the DG834PN - but I would stay clear as the wireless on it isn't even ratified.
timps
netgear834
thx Gotdsl ..purchased DG834 and so far i'm more than satisfied set up a doddle very intuitive
thx
timps
repcomms
netgear834
Can anyone say what the different prefixes and suffixes mean. I have noticed they do a WGT834 and a DG834. Had not picked up on the GT and PN suffixes. I was thinking of using the WGT834 which has the USB port for network storage. I do not think the DG834 has the USB port but I could be mistaken. Cheers, Bob
netgear834
The DG834 is a wired ethernet 4 port modem/router. No USB port.
See >>link<< and >>link<< for different prefixes and versions.
netgear834
Hi, noddy question time. I am thinking about getting a wireless router (probabley the D384) in preparation for an impending house move as there is no phone socket where I intend to setup the PC. The question is can you configure the router wirelessly?
netgear834
not a noddy question at all, but not sure what a D384 is.
However if you mean a Netgear wireless router or modem/router, DG834s etc. can indeed be setup wirelessly.
However, it's usually recommended to do all the initial setup while wired (including setting up the wireless side).
netgear834
Thanks for the reply, I did actually mean the D834 but I can't type Cheesy . Sounds good on the setup so I should be investing in one of these shortly, probly a bit nearer to pay day
iPaqowner
netgear834
You still can't...it's a DG834
netgear834
I know but what's a G between friends :lol:
netgear834
ummm? is the answer friGends? :lol:
netgear834
Hahaha! :lol:
