netgear dg834gt channel change
be grateful for any ideas here. i tried to change the channel on my router as i wondered if the up and down speeds i've been getting were anything to do with that .... but now my laptop won't even pick it up as an available netowrk now.
also, i can't even get into it via the isp number any more.
1 REPLY
Get netstumbler from
http://www.netstumbler.com/
And see if that will pick up the router its handy as it shows the traffic on the channels.
Often the problem is whether you use windows software to find a router or OEM software. Try using windows software to find it.
Can you get onto the router via a cable to check if its working.
