linux with voyager 2110
Hello
Has anyone successfully configured linux to use the BT voyager 2110 ?
I am dual booting Suse 9.2 and Windows XP at the moment. Windows ok, but would apreciate some help with Suse if poss. I'm not very experienced with linux.
Thanks. Brian :?
Is your networking working under SuSe?
Also are you trying to connect to the Voyager via wireless, if so I would suggest starting with a wired link. To get the network set up then try moving back to wireless.
Are you able to login to the Voyagers web administration page using its IP address, that would be a starting point.
Chilly
voyager 2110 and linux
Thanks for the tip chilly. A cable was supplied with the modem. I will try hard wiring first.
Thanks, Brian
