help - can't get online with PHILIPS snk5620/05
Hi all, i bought myself a PHILIPS SNK5620/05 MODEM ROUTER AND USB ADAPTER from pc world the other day. initially i was having problems, but then i was advised to connect through the ethernet cable initially for setup, then switch to wireless.
everything seemed to be going well and the built in modem was recognising the speed of the line, but it won't connect. I have checked all my login details and they all seem to be correct.
Is there any address i can type into a browser to carry out tests or finish setup??
Please, any help is extremely appreciated.
Paul Doherty
1 REPLY
You could try the bt speed test as this doesnt need a password.
http://usertools.plus.net/tutorials/id/27
What errors do you get?
