curious
curious
Hi i have a IEEE1394 socket on the frount of my tower and a constant 400Mbps conection on my screen can someone tell what this is used for Shockedops:
Alecto
curious
If you google on IEEE1394 you will see that it is otherwise called "firewire". If you don't have any firewire devices, just ignore it.
Try Google to find out all you want to know.
holdtight
curious
As Geoff says if you dont have any firewire devices ignore it and if you go into control panel then network connections right click on 1394 Connection and select disable it wont show in your system tray anymore
Just remember to enable it again should you want to use a firewire device in the future
