belkin router
belkin router
ok i have a belkin adsl-modem and router it has wireless i have a pc upstairs with a wlan card and it wonr connect there is no pass for my router connecting settings
belkin router
Check on your belkin router settings through IE, if you have a MAC address restriction set.
Your PC will never be able to connect if so, as the router will not allow it, as it is not a recognised MAC address.....
belkin router
I purchased - and returned - a Belkin modem/router and PCMCIA card from Dabs. (Here, FYI:http://www.dabs.com/uk/channels/hardware/modemsandadslhardware/productView.htm?quicklinx=3n6t)
I found it's range to be very limited indeed - no more than two or three metres at best. I'm not the only one to experience problems with Belkin wireless gear.
And yes I did change channels, remove all potential sources of interference well away and so on. Seems that some can work fine and their users are very happy with them, but others are simply rubbish.
