Zyxel 660HW-T1 website access
scubarew
I've just bought and installed the wireless router listed above and it's working remarkably well apart from one small thing. I can't access a couple of very specific websites and I just can't figure out why. So far I know I'm being prevented from accessing www.zyxel.com, www.zyxel.co.uk (which doesn't help when trying to find support info!!) and the Computer Associates ezAntivirus update website.
I've played with the firewall settings and turned them on and off but nothing seem to make any difference.
If I switch back to my old PCI modem the websites work just fine.
Anyone got any ideas? It's my first wireless router so I'm floundering a bit.
Can you try connecting to a different gateway? Some people are reporting problems accessing websites when on certain gateways - This probably happened when you disconnected to use a different modem anyway.
scubarew
Just came back from elsewhere and it's now working even though I've not changed anything.
Thanks for replying even if I am still as confused as before :shock:
