Wireless connection for Xbox Live
StuWard
I currently use a Linksys wireless card in my office pc to allow this laptop to connect to the internet. Can i also share my connection with a 360 using this card and a wireless adapter for the Xbox ?
Is it just a case of using the changing ip of the xbox ?
Stu
1 REPLY
Your PC and Xbox will be able to share your connection at the same time, however I do not really understand your post but if you are intending to connect your Xbox 360 wirelessly you will need to buy the xbox wireless adaptor (if it doesn't already have one) or alternatively a wireless bridge. I have had compatibility problems with wireless bridges so I would stick to the same manufacture - ie, if you have a linksys router, get the linksys WGA54G gaming adaptor (for instance).
HTH
