Wireless and XP Service pack 2?
A puzzle for you all...
I have developed a problem with a notebook and wireless access, which worked flawlessly for months, WEP enabled, and then suddenly it would not connect wirelessly. There is no problem with a cable connection.
A wireless desktop is a bit temperamental, but works well most times, and an Ipaq continues to connect without a problem, so I'm pretty sure the fault lies within the notebook, and probably software related.
I think this could be related to SP2, or some other "update" but having removed SP2, at the suggestion of the notebook manufacturers (Hi-Grade - new in 2004) there is still a problem. I think I've done everything else ( e.g re-install drivers, setup the wireless connections again etc.,) except change the hardware in the notebook. I don't really want to format the notebook and start again!
(Netgear DG814 Modem, Belkin WAP F5D7130)
Any suggestions most gratefully received.
Not sure about the router model, but on a different netgear router, you have to add your machine to the 'access list' as a trusted station.
This is based upon the physical MAC address of your machine, rather than just relying on windows names, I think.
I'll have a dig around, because perhaps I am wrong.
Thanks James,
Since posting earlier today I have tried to access the Belkin WAP's user interface by entering its IP address, and seeing whether a firmware upgrade might sort it.
I can't access the WAP at all at present and now wonder if the WAP is faulty. Also the Ipaq fails to establish a connection. Looking back, what I have assumed was just an intermittent poor connection in the past may be a more serious hardware fault.
Regards,
Robert
PS: Nice cat
Thanks, the girlfriend allowed me to call him Roger, without realising the implications.
Wink
Curiouser and curioser....
Wi-fi is now working again, but I can't access the user interface by entering 192.168.2.254 into browser from a wired machine, and therefore can't do a firmware upgrade....?
(All firewalls etc., switched off)
Any thoughts anyone, please?
Many thanks,
Robert :?
P.S Our elderly cat Tom, is being threatened by the arrival of the wife's new dog! At present we are resisting..........
What is the IP address of the wired desktop, command prompt ipconfig /all? It must be on the same subnet as the AP. What error do you get?
Thanks,
IP address 192.168.0.6
No errors
Well you could be on a different subnet with this address depending on the subnet mask. Is the wired connection using a static address of DHCP? Does the gateway interface have some restricted access? In which case the allowed IP addresses to access the interface maybe in a very small band.
