Wireless(U.S.Robotics) is not working!!
Hi
i have wireless (U.S.Robotics Sure Connect ADSL Wireless Gateway) and it isn't working because it says "No Line" but its says wireless is enabled so what does that mean? also before the wireless would work prefectly fine everyday but nowadays when we try it, it shows ADSL like flashing slowly and den it goes fast, i believe it shouldn't be doing that because it means A DSL Link is being negotiated. So i duno what to do. also i try resetting the gateway, i check all the wires and everything fine there. can anyone help
You need to logon to the gateway and see if it has any error messages and if it show that its connected or not. The adsl light flashing could be some one else using your router. I dont know this router but most have a page which shows whos connected.
Can you connect to the internet or not?
Wif the wireless i cant but wif my original modem that plus.net gave i can
That prove the adsl is up ok. So you need to logon to the gateway and make sure the username /password are correct and the setting are ok.
I would think its one of the settings failing that then its a duff gateway.
If your not sure on the setting post what you have and we can tell you if they are right
