Wireless Network
Wireless Network
I have two WiFi enabled PCs and i am trying to set-up a wireless network.
Do i need a router or can a network be setup without one?
Wireless Network
If you only want to join the 2 up wirelessly and dont want to share internet access then no, you do not need a wireless access point / wireless router. Cant remember how to do it in Windows but you need to set both PC's up for "Ad-Hoc mode" and setting the same wireless parameters for both.
Wireless Network
You have to set up both wireless cards in Ad-Hoc Mode so they detect each other. You would then need to set up File & Printer sharing on one of the machines.
You can set up Internet Connection Sharing depending on the modem used, but to be honest it can be fairly complicated.
Some more info can be found Here >> http://www.microsoft.com/windowsxp/using/networking/expert/bowman_02april08.mspx
