Wireless Network (Belkin pre n) urgent help
OK folks I hope someone will be able to help
Running with xp sp2
got myself a belkin pre n modem/router and wireless pre n desktop network card
all was well untill 30 mins ago and it just stopped working now using cable to get onto net.
when i try to conntect it comes up with wireless network connection 6, why do i have 6 connections ?? and do i need that many??
and do you think i need to uninstall the desktop card and then reinstall it?
have a wpa security set up on it but will not connect. Have tow othwer wireless networks close by in my block of flats but untill now they did not bother my set up
Hope some one will be able to help on any of the above
do i get to network 7
1 REPLY
Slick
contact me on msn and il try to assist you paulslack575@hotmail.com
