Wireless Card Drivers
I don't suppose anybody knows where I can download the drivers for the
UTstarcom wnic1015 802.11b wireless network pcmcia card
do you?
I have had to install windows on my laptop again, so that I can use it on the college network, however I didn't realise before I did this that I don't actually have the drivers for my wifi card
I can't find the flippin things anywhere.... Sad
1 REPLY
Atheros Client Utility
Check your card if it's Atheros based, if yes you can download the Atheros Client Utility from another card producer and use that driver.
I have got a Netgear and an Edimax 108 G card, the both based on the same Atheros chip and I use the Edimax driver for both which is practically the orogonal Atheros Client Utility because it's much better than the original Netgear driver.
I hope it helps,
Bertie
