Which Router
Which Router
Hi, Can you guys suggest a good router, either wired or wireless, I'm thinking of going for LINKSYS WAG54GS, although I'm using a pc and voyager 210 router, I need to upgrade coz, I need a solid router, not a dogdy one like BT voyager, to something good, I'm fed up with the entire BT range of products, which includes their studio range of cordless phones.
The other factor is the recent price cuts for this routher, Its now avilable for £60, which almost £30 cheaper than its original price.
Please put your comments here.
1 REPLY
Which Router
Netgear DG834G - Has one of the best wireless ranges around, is simple to setup and can cope with very low SNR levels which makes it ideal for MaxDSL.
