What is Wireless User Isolation?
Does anyone know what "Wireless User Isolation" does and when it should be used?
By default it is disabled on my Voyager 2110.
Thanks,
Mo
Wireless User Isolation, is normally reserved for public hotspots.
It isolates each user, so that other users of the hotspot can not connect to your machine via the access point.
This is great at public hot spots as someone could use the wireless network to hack your machine. (Hence you should always use a firewall.)
But is of little use domestically where you may wish to share files or printers between wireless machines.
Chilly
Without going into all the details I'll take it for granted that I don't need to enable this setting.
Thanks,
Mo
