WAG54GS
Craigiusmaximus
WAG54GS
Bit of a strange one this but............. for the people with a linksys wag54gs when you are connected to the net on a wireless connection could you tell me what colour the light is on the front of you're router the one with the padlock on is it blue or greenHuh
essenby
WAG54GS
Mine is amber! all the other lights, Power, Wireless, DSL, Internet and the port connection lights are all green.
Craigiusmaximus
WAG54GS
sounds ok to me its just when you set it up it flashes blue!!
WAG54GS
Green all the way.
Are you on DSL Maxi minus
or adsl2 or 2+ (LLU)
Could it be that it changes depending what type of dsl you have?
A
WAG54GS
I set one of these up a while back for someone..
can't remeber exactly but I think it lit up blue when it was running without security or it was in "training mode" or something. I just set it up manually and it was green.
Craigiusmaximus
WAG54GS
Yeah i think you are right when the security is on i think it is green.......................... i just want to make sure my network was locked down from the outside i got a laptop off a mate to have a look and it is all secure which is what you need!
Cheers people
Craig Cool Cool
