Voyager 1060 installation problem
I am having problems installing the Voyager 1060 laptop adapter.
After I insert the adapter (when prompted), I get a file not found message ('BCMWL5.SYS').
The PlusNet help line's best advice was to contact the manufacturer. All well and good, except they have limited opening hours.
Regards,
Hi There
What operating system are you using and do you have a service pack update on this machine as well? Let me know and I will see what I can advise.
I have Windows Millennium.
I'm not sure what you mean by 'service pack update'. If you mean has the machine been upgraded/maintained since purchase in any way - then no.
Sorry to be vague - I'm generally a non-technical user.
Thanks for your help,
