Trying to connect to Netgear DG834G
I am tryign to connect to my new Netgear DG834G router and when i type in all the details it doesnt connect to the internet.
I use these settings:
Does your internet connection require a login - Yes
Encapsulation - PPPoE (PPP over Ethernet)
Login - attom@plusdsl.net
Password - .......
Service Name - Plusnet
Idle Timeout - 0
Internet IP Address - Get Dynamically from ISP
Domain Name Server (DNS) Address - Get automatically from ISP
NAT (Network Address Translation) - Enable
And i cant connect to the internet any ideas please?
you need PPPoA rather than PPPoE i expect
jazz
Trying to connect Netgear Wireless Router
I'm no great expert but I think you need the Encapsulation to be PPPoA(PPP over ATM)
Hope this helps :roll:
Mine is working fine set to PPPoA(PPP over ATM) on BT wholesale.
Have you tried just running the setup wizard, that found these setting for me.
Chilly
Nick_Russell
The DG834 should connect automatically. I think you only have to enter user name and password if you use the wizard. See these guides...
http://www.thinkbroadband.com/hardware/reviews/2004/q3/netgear-dg834g.html
http://www.thinkbroadband.com/hardware/reviews/2004/q2/netgear-dg834.html
Yes, should be PPPoA. I also find it's better to enter the DNS servers manually - 212.159.6.9 and 212.159.6.10
The_10th
