Thunderbird Email Client & SMTP Issue
Email is still sending fine through Outlook but because it has crappy anti-spam, ive installed the free Thunderbird (latest version) software which is great BUT, im having issues sending email!
I just imported all the settings from outlook and incoming email is fine, i just cant send emailSad Ive compared both account settings on thunderbird & outlook and i cant notice anything different!
Ive tried sending with antivirus (norton) off but it didnt work and with my firewall off (zonealarm) but it didnt work.
I should mention that when i click send, a password request for relay.plus.net appears - i enter my correct password but it just pops up again, like ive entered the wrong password. Ive tried other passwords just incase but its definately the right one i try to useSad
Any help?Sad
lingbob
Neither a password nor a username is required to send mail via relay.plus.net
In thunderbird:
tools -> account settings -> outgoing server (SMTP) -> (usually relay.plus.net) -> edit -> uncheck "use name and password" and use secure connection should be set to "no"
Oh, hmm well that seems a bit crazy but its worked!Smiley
Cheers peeps!
i did not get this to work, any ideas
Liam
Are you connected to our network at the time?
You need to be on a Plusnet connection in order to send emails via our relay servers.
kopperdrake
Excellent - that just sorted out my question too Cheesy
Awesome, thanks Smiley
Richchad
Okay can send email from Thunderbird now but still cannot receive from PN :?
Checked all details, looks exactly the same as OE :?:
