Thomson SpeedTouch 330 ADSL. Looking for a compatible router
Currently have a Thomson SpeedTouch 330 ADSL.Looking to get a wirelass laptop computer can anyone recommend a suitable and compatible router :?: :?:
If you get a router you will ditch the modem so its not relevant.
Any router should be fine ie Netgear, Linksys etc unless you need something special.
you only ditch the modem if you buy a modem/router
