Setting Up Remote Access
My friend would like to set up his wireless Router so that he can connect in to his PC upstairs from his wireless laptop downstairs. I know how to use Remote Desktop and the dynamic DNS function of a Router to set up remote access but I believed that this would only work between domains. Could anyone tell me if this kind of setup would allow my friend to do what he wants to do?
1 REPLY
You just use remote desktop its dead simple. All you need is for the laptop to be in the same ip range as the desktop and then type in the ip address of the desktop.
To work best the desktop need a fixed ip as with that there is no DNS needed. you could also use any remote software like VNC as with that it wouldnt log anyone off using the desktop
