SSID: 'BTOpenzone' or 'BT Openzone'
stephenday
Hi
I have just subscribed to PlusNet's BT Openzone service.
Can anyone tell which is the correct SSID to use? The plusnet webpages say I should use 'BT Openzone' (with a space) but BTOpenzone.com says I should 'BTOpenzone' (without a space). Do they both work or is one of them a typo?
Cheers
Steve
1 REPLY
No space.
The configuration program will normally list all the available SSID’s for you, when you try connecting to a wireless network.
Chilly
