Router Advice
Router Advice
Hi can anybody have a cheap Wireless router that i can use with PLusnet.
I have a dlink one and got it connected but it will not pass the DNS traffic down to my Laptop?
Router Advice
Do you mean you are getting dns errors on the laptop. What is your dns set to on the laptop? You can set it to the ip of the router and in most cases this is fine but its often better to point the laptop to plus nets dns.
Can you get out and ping using an ip ?
Router Advice
No it will not ping either, the Modem is connecting to PLusNet fine, i've tried applying the DNS from the modem and also manually.
