Problems Sorting Wireless Security on Netgear DG834GT
Hello
I wondered if someone could help me I have purchased a
Netgear DG834GT wireless router and had no problems setting
up the wep key but then my router reset and now everytime
I try and reset the wep key it comes up with the connection
was reset and I cannot set the wep key and have to reset my
router anyone who has suffered the same or can help it
would be great.
Many Thanks
1 REPLY
What are you setting the key on the router or the pc? If its the router and it wont accept the new key do a factory reset by pushing the button at the back.
If its the pc its trying to connect with the old key and saying connection refused but you should then be able to reset the key but this is down to the software the card is using
