Netgear DG834GT
Netgear DG834GT
I've got a DG834GT, it's meant to be capable of 108Mbps but i've never been able to achieve this speed even with the receiver sitting beside the router. Has anyone managed to get 108Mbps out of this router?
Paul
Netgear DG834GT
What wireless card are you using to communicate with it.
108Mbs is a propriatory speed so standard 802.11g wireless devices will never communicate at that speed without them also supporting the propriatory protocols.
Netgear DG834GT
It's just the standard WG111T usb dongle that came boxed with the router, it may not support 108Mbps, i didn't check it out i just assumed it would.
Netgear DG834GT
The WG111T does support 108Mbs speeds but you may need to configure both the router and the 111T to support the non-standard speed.
