Max dsl and Belkin Pre N modem/router
Hello
Hope someone can give advice
I have been looking at folks going on about Maxdsl and i am sure I will get it at some point and looking forward to it when I do.
Do I need to do anything as in do i need to mess with my modem/router or will it all be done for me Huh
Anyone know how i can look at my Belkin pre n modem/router to see if I am getting thr higher speeds and anyone know what to look for ??/
so many whats but i am sure someone will be able to give me info
I know if i go to 192.168.2.1 it takes me to my modem/router setting but no idea what I am lookign for
1 REPLY
You don't have to do anything with your router when you get MaxDSL, the routrer will just automatically sunc at the higher speed when its enabled on your line.
I don't know how different the Pre-N version is to other models but the line stats may be in the same place - see http://www.kitz.co.uk/adsl/frogstats.htm on how to find them. That area should also give your the connection / sync speeds.
