How do I convert a Netgear DG834 to wireless?
Hi,I have a wired DG834 but I understand that you can convert it into a wireless router. Could someone tell me how to go about doing this please?
TIA Simon
You cannot 'convert' a DG834 to support wireless.
What you can do is buy a wireless access point which connects to the router via one of the 4 ethernet ports to give you your wireless capability. However, beware that not all wireless access points work with all routers.
http://www.ebuyer.com/UK/product/46057
http://www.ebuyer.com/UK/product/112497
http://www.ebuyer.com/UK/product/99754
to name a few......
I've used the belkin in the past as a range extender, was 100% reliable Cheesy
I think at those prices I might as well buy a new wireless router!
The reason I want wireless is that my PC is so far from the phone socket that I need a 20ft lead to reach the router. Even though it's well insulated and I keep it away from other leads I think this must be affecting my line speed.
Do you think I'm right in thinking this?
If it’s convenient to run a cable from the phone socket to your PC, why not place the router at the phone socket. And run a Cat5 cable to your PC, this will be more immune to interference than the phone cable.
www.maplin.co.uk supply Cat5 cabling, or PCWorld but they are very pricy.
Chilly
Have a look at this link and read the comparison test.
I wonder what others think of this, as I am really tempted to go this way.
Not decided on the cleanliness of the ring mains at my address though.
http://www.solwise.co.uk/net-powerline.htm
