How best to share internet connection?
dsmail
I currently use a Zoom dsl usb modem to connect a stand alone desktop to the internet. I now need to share this connection with a laptop and know very little about this stuff. From what I can gather, I need either a wireless router to use with my existing modem, or a wireless router with a built in modem. Which is the best option? Which is the best value kit to purchase. Is this easy to setup? Any advice gratefully received.
Dave
A wireless 4 port router can be had for about £55
You can also get a wirless access point that will plug into a LAN socket for about £35.
As you probably dont have a LAN socket from the USB modem then your best option would be to go for the wireless Modem/router.
This will also give you the additional options of connecting other things to it via the 4 LAN ports. Other PCs or even an X Box
They are easy enough to set up and most also have built in firewalls.
I have used both D-link and Belkin with good results form both.
dsmail
Thanks for this info. Very usefull.
Dave
Could not the access point be plugged directly into the Zoom modem? This modem has a router and DHCP. May need to use a crossover cable.
dsmail
Would this be appropriate for my needs then?
http://www.dabs.com/productview.aspx?quicklinx=395K
Dave
