Help with setup
Help with setup
I want to set up a home network with wireless broadband access to the internet, but I don't know what I ned for this. The more I read about, the more confused I become!
My current setup is broadband access from my desktop using an Alcatel pci broadband card running under Windows ME. I want to set up a LAN to include 2 additional laptops running Wiondows XP each with 802.11g mini pci cards, so that all 3 machines can share broadband access. I also want to be able to share files between the 3 machines wirelessly, and share a common printer wirelessly.
What is the best router for this? Ideally I would like one with 108 mbps for future upward compatibility. I think it needs to have a built-in broadband modem as well; is that right? So my existing broadband pci card would become redundant. I also think that I need to buy a separate pci router for the desktop, as it doesn't have an ethernet port.
How does the printer fit into this setup? Can I leave it hard-wired to the desktop (via a usb connection), or should it have another wireless device of its own?
I would appreciate any help on this matter.
Regards, Dave.
1 REPLY
Help with setup
Rather than writing a long winded spiel see this for advice and guidance as to what you need.
Hope this is of help.[/url]
