Help with router setup
Andrea2006
I have a d-link di-624+ and i try to set it up. I have got the option up, which says
Dynamic Ip
Static Ip
PPPoE
PPTP
Which do i select.. If i select Static IP i will get this
WAN IP ADDRESS
WAN SUBNET MASK
WAN GATEWAY ADDRESS
PRIMARY DNS ADDRESS
SECONDARY DNS ADDRESS
What do i put to those??
TIA
Hi Andrea2005
Which broadband product are you currently being supplied by plusnet?
The reason why I ask is that broadband plus has "dynamic" IP allocation.
Let me know, and I'll see what I can do to help Smiley
Roger.
Andrea2006
PlusNet Broadband Premier Option 1
Hiya,
If I remember correctly, with the exception of one or two packages, your IP address will by dynamically assigned.
So.. click on the dynamic IP option
Connection type will be PPPoA
VPI/VCI will be 0,38
Your username will be in the form of yourname@plusdsl.net
and of course, your password Wink
And finally, leave your DNS settings to be "Autodiscovered" or "Automatic"
I hope this helps.
Roger,
