Help linking powerbook G4 to exisiting wireless network
Hello,
I'm currently using the Voyager 2110 Wireless Router with a PC and its all going fine, but I'm having trouble setting up the connection on the powerbook.
I've just got a Realtek (Rtl8139) WLAN airport card in order to connect to the net but I can't get the WEP key to be recognised. I've specified that Data encryption is via WEP, and that the key length is 128 bits. I've then entered the code, but when I click apply I get a message saying "ERROR The length of the key index 1 is not correct".
Can anyone help?
1 REPLY
pixgunnill
If you WiFi system is working already the PBG4 should <see> your network straight away. If you of course have turned Airport on, on the top menu bar. Good luck
Mike
