Email from openzone
Email from openzone
I have signed up to openzone itself as I want to use it in Europe from my PDA.
However dispite tring all the settings for Incoming and outgoing mail as recommended by openzone I have not managed to send or recieve email via plus net with it .
OK yes I can use web mail but that takes longer on line.
I would be greatful for any advice.
LiamM
Email from openzone
You should be able to receive email fine through mail.plus.net (imap.plus.net if you use IMAP email).
Not sure on BT Openzones outgoing email server however.
Email from openzone
If using a Openzone hotspot, you should set your outgoing mail server to smtp.btopenzone.com
