Do you use Sitecome router?
A friend directed me to Maplin, which is selling a Sitecom router 54g at 35£ . The price is very cheap and tempting.
However, since my budget allows me to buy something more expensive, I want to know if this Sitecom router is fast enough. I don't know anything about this brand. Is it good?
The hardware concerned is here:
http://www.sitecom.com/product.php?productname=Wireless+Network+Broadband+Router+54g&productcode=WL-...
Thank you for your help.
Having downloaded the spec from the site and looked at it then it shows that it doesn't contain a modem. Thats why its so cheap. Its just a router and will need an additional modem to use it on its own.
There are better deals around Sad
Thank you for your quick reply. Cheap deals are really complicated. We can't take them at face value.
