D-Link Wireless Router Connection Problems
Hi, Can someone please help me. I have installed a new D-Link DSL-G624T wireles ADSL2/2+ router. Set-up seemed fine using supplied disc but cannot connect to internet. IE page comes up with the phrase "Access Denied by access control list". Windows firewall is switched off. I have set up remote access via my laptop and this is working perfectly!! please help!!!!
David
Can you make it clear for us
Can the laptop connect to the internet?
Is the main pc connecting via wireless?
Does the router say its connected?
From what little you say it sound as if you have setup encryption or access for only known MAC address and you have not entered the key right or not added mac address.
Turn off wep or anything like to see if it then works and look for any firewall settings on the router as the error is saying its a firewall type issue
Thanks for the reply but i got the syetem fully working now. Just did a reset on my IE explorer settings to restore the defaults and everything now works like a dream!! Cheers
