D-Link Dl-524 wireless modem WITHOUT an ethernet card
Can anyone advise me how I install a D-Link Dl-524 wireless modem WITHOUT an ethernet card in my PC as the "Quick Install" insists on it being present. Previously I have attached to my modem using USB.
TIA
B
1 REPLY
if you simply power up the router, you should be able to access it via its LAN IP from any connected wireless client for example enter: http://192.168.0.1 in your browser
check you user manual to confirm its default LAN IP
Cheesy
