Connection Time
Connection Time
My internal broadband modem always connects but sometimes it takes up to 10 minutes before I get the "ding" sound to show it's connected. I can hear the modem clicking as if it is constantly trying to connect. Anyone else experienced this? Is there a solution or is it fairly normal?
Kev
Connection Time
Anyone help?
Kev Cry
Connection Time
It would appear that you may have posted this in the wrong forum.
Unless your internal modem is also a wireless device.
If it is wireless then accept my apologies if it is not then maybe Mod will move this to a more appropriate section.
Connection Time
Are you sure it is actually BROADBAND? Internal or external modems don't usually "click" except for normal dial-up types which have a relay to pick up the line. Sounds like a dial-up narrowband with a weak or dodgy phone line.
Connection Time
No, definitely Broadband. I'm with Plusnet and connect at about 570. It eventually connects then everything is alright but the modem clicks as if it is swithching on and off sometimes for 2-3 minutes
