Changing to wireless
Hi
I have a four port Origo router with built in ADSL modem I use to connect to Plus Net.
I would now like to set up a wireless network to connect my sons PC in his bedroom and am trying to find the cheapest and most reliable way to do this.
Most hardware set ups I have seen seem to include a wireless router with built in modem but I was wondering if there was a way I could utilise my existing Origo hardware?
If not what is currently considered the best wireless router to go for?
I should add that my sons PC is a Shuttle XPC and so has limited PCI slots available so I intend to use a USB adaptor at his end unless someone tells me this is real no-no.
Thanks in advance.
Dave
You just need to connect a wireless access point to a spare port on the router, and add a wireless PCI card or USB adapter to your son's PC.
The wireless access point doesn't need to have routing capabilities, you already have a router.
However, Wireless Access Point (WAP) devices tend to be expensive (around £50 for a 54Mbs 802.11g) and you can get a new wireless enabled modem/router (e.g. Netgear DG834G) for around £70 which is what I would recommend you do as it simplifies the setup.
D-Link 54g access point - £40.39:
http://tinyurl.com/6mwpa
LiamM
Or this one...
http://tinyurl.com/56eas
Very similar to what you have, since Safecom (the manufacturers of that one) are just the newly rebranded Origo. Very easy to setup through Web Interface. I would expect exactly the same as your current router.
Or this one...
That is quite tempting as at £14 more than the access point I end up with one less box cluttering up the place. I could keep the Origo as a backup in case of failure as well.
Thanks for all the replies.
Dave
LiamM
Yeah. I have used a number of Origo Wireless routers (which are now those Safecom ones), and haven't had a problem with any but one which was simple to fix.
