Centrino Laptop with Linksys WAG54G
Has anyone had any problems connecting a Centrino b/g based laptop with security to a wireless gateway?
I can connect mine and it works perfectly with no encryption Shockedops:
If I turn on the encryption the laptop picks up the gateway and asks for the key but stalls on "aquiring network address" :roll:
Waiting for Linksys to reply.
Are you using a HEX or Plain text key?
Also try different levels of WEP.
Chilly
I suggest opening your Wireless configuration manager for your the Centrino card, and deleting the profile for the router.
Now try reconnecting with Encryption enabled on the router.
I have problems with my wireless card, where I switch from non-encrypted mode to encrypted mode. It is as if it doesn't change all the settings needed for that saved profile.
Have tried that with re-starting the router and pc as a bonus but so far no good.
Chilly
Plain text with 64 and 128 bit encryption but with no luck Cry
Try using HEX keys. I had a problem where plain text keys did not work, but entering the same key as HEX did work.
That was also on a WindowsXP laptop.
I have also had to drop WEP to 64bit, for the same problem.
Chilly
Chilly
Thanks Chilly I will try that and let you know. Cool
It works!
Thanks for all your help I now have encryption! Cheesy
Linksys got back to me and basically told me to remove all the configurations for the Centrino, a reset on the router, configure the router and lastly the card.
Bingo Cool
